What are people buying?
Re: What are people buying?
Also, I need to convert one of my figures to a sniper.
I usually just use a generic rifleman but I’m feeling the need for some specialness.
Isn't the Warlord one the Char B1 Bis? The Char 2c was a monster...tim.w wrote: ↑Sun Nov 10, 2019 9:13 pmSame. You can get resin or kit versions from Warlord. You've put me off the 105mm gun.Norman D. Landings wrote: ↑Sun Nov 10, 2019 5:39 pm I’m toying with the idea of getting a Char 2c for my WWII Frenchies. It looks splendid and carries ALL THE MACHINEGUNS.
https://store.warlordgames.com/collecti ... ifle-teamsNorman D. Landings wrote: ↑Mon Nov 11, 2019 7:57 am Also, I need to convert one of my figures to a sniper.
You can get either (or both) from Warlord:Shahbahraz wrote: ↑Mon Nov 11, 2019 7:59 pm Isn't the Warlord one the Char B1 Bis? The Char 2c was a monster...
https://store.warlordgames.com/collecti ... har-b1-bis
https://store.warlordgames.com/collecti ... heavy-tank
The WLG starter army I bought off of the eBay already contains the light mortar & the ATR - and I have half-a-dozen generic crewmen with binox who could be the spotter - so this pack is largely redundant.BaronVonWreckedoften wrote: ↑Mon Nov 11, 2019 10:33 pmhttps://store.warlordgames.com/collecti ... ifle-teamsNorman D. Landings wrote: ↑Mon Nov 11, 2019 7:57 am Also, I need to convert one of my figures to a sniper.
Just need to drape a camo net over a rifleman and put him on a base with some heavy cover.
Re. the 105mm gun, though... in hindsight, Irregular’s ‘really useful gun’ range includes French issue WWI Schneiders, and both Dutch and Belgian WWII howitzers - very straightforward kits by the look of it, and all of six quid. Doing it again, I’d consider one of those as a proxy.
A points-free medium howitzer is too good to pass up entirely.
Last edited by Norman D. Landings on Tue Nov 12, 2019 3:19 pm, edited 1 time in total.
A tank for which you can legitimately field the entire production run...Shahbahraz wrote: ↑Mon Nov 11, 2019 7:59 pmIsn't the Warlord one the Char B1 Bis? The Char 2c was a monster...tim.w wrote: ↑Sun Nov 10, 2019 9:13 pmSame. You can get resin or kit versions from Warlord. You've put me off the 105mm gun.Norman D. Landings wrote: ↑Sun Nov 10, 2019 5:39 pm I’m toying with the idea of getting a Char 2c for my WWII Frenchies. It looks splendid and carries ALL THE MACHINEGUNS.
- Vintage Wargaming
Norman - Really Useful Guns are designed to work for both 15mm and 20mm so might be a bit small for you.
You can never have too much of something you never needed to start with
Some of my blogs:
http://vintagewargaming.blogspot.co.uk/
http://findthatfigure.blogspot.co.uk/
http://tankdevelopment.blogspot.co.uk/
http://georland.blogspot.co.uk/
Some of my blogs:
Mais non, mon ami - they also do the same RUG range for 28’s. (25 to be exact).
Top of their 28mm listings, third entry down.
Just bought a Schneider.
Don't forget the butter, Marlon......
Mind The Oranges Marlon
- Vintage Wargaming
Never knew that, but then I only ever buy them for 20mmNorman D. Landings wrote: ↑Tue Nov 12, 2019 2:07 pm Mais non, mon ami - they also do the same RUG range for 28’s. (25 to be exact).
Some of my blogs:
Some of my blogs:
